Yup, en als j'm hebt, man je zal nog verschietenWelke Bambu printer voor mij
Tot dat je de versleten onderdelen moet gaat vervangen .Toledo85 schreef: 05/12/24, 16:48 Even een update het is de Bambu Lab x1 combo geworden....wat een machine zeg....
Bambu Lab X1C
December 3
Get Real about Bambu Labs
slatinmotogear
slatinmotogear
Hello All,
I have been a fan of Bambu Labs since the early days, that is until recently. I have more than 4,000 hours on my X1C, having bought one of the first to be sold. What precision, what joy, what a great functioning machine. The best at its price point. However, as a product manufacturer myself, having a great price, great functioning machine is only two thirds of what makes a product great. The remaining third is all about servicing. That is where Bambu Labs drove off a cliff, and crashed on the rocks below. I’ll explain…this machine was developed and manufactured in China, which has become 'the world’s factory. I have nothing but respect for its people, their hard work and the ambition that is the driving force propelling their great accomplishments. But Bambu Labs has some serious flaw, flaws I have brought to their attention, flaws that they have turned a deaf ear to, which is an adult phrasing that means they won’t listen. Assuming that the western market is a good chunk of their global market, they have made two serious mistakes. First, the design flaw I will get to momentarily. Second, one this flaw was brought to their attention, they did not correct. 4,000 hours is a lot for any machine; its expected that parts will wear out, break, or both. As users, we are told to consult the Wiki; a great place with video instruction, clarifying information, you name it. But their are fundamental differences between East and West, that cause problems; in short, Americans generally have larger hands than Asians. This isn’t ignorance talking. I discussed this with my Chinese-American friends, and the consensus is, that if you are gonna work on these machines, you need slender fingers, I’m not overweight, not a bit, but working 1.5 mm screws in spaces in which you have to turn the machine sideways and hang upside down to remove/install some of the important parts. Its also extremely hard lining up screw holes for installation/assembly and there is no room at all to eyeball it. The plug behind the TH9 motherboard, for instance. The Wiki is good info, but toss the instructions. The best way to replace the TH9 boards, with/without a new micro lidar is to remove the front and back of the toolhead and carefully insert the lidar plugs into the TH9 mother board, THEN put the boards into place and screw both boards down, Next, insert the remaining plugs into the respective sockets. Oh, yea, screwing the boards onto the tool head is not overly difficult. But working 1.5 mm screws into the toolhead’s receiving holes??? That is no 10 minute job. I spent hours trying to line up holes, and used a lot of words not suitable around children. Here’s how I did it: assemble side and rear toolhead covers, placing them into position on the toolhead. Next, unless you have three hands (forget it, there’s no room for a third hand in the square space, with the glass top off.), use zip ties to hold the rear and side parts of the toolhead cover together, in place. Next, while you can see the holes in the toolhead cover, you cannot see the underlying holes that the screw anchor into. I have a gooseneck inspection device with a lit optic cable feeding an image onto a monitor.
likes 40 replies 17 Read More
Yup, dat heb ik in het verleden ook aangehaald in een ander combo. Ze zijn niet de gebruiksvriendelijkste als het op onderdelen verevangen aankomt, MAAR wanneer het zover is hebben ze wel een uitstekende wiki. Ik heb de th boards EN lidar zelfs 2x vervangen. Zo moeilijk is het echt niet dat bovenstaande persoon doet uitschijnen. 4 schroefjes en voor en achterkant zijn los en kan je er compleet afhalen, en dan kan je gelijk ook het middenstuk van de toolhead cover losdoen.
3 schroefjes en achteraan en 2 vooraan en de hele PCB van th board en main toolhead board komt los. Kabels zijn jst dus die zijn van nature klein. Op een half uurtje tijd had ik het main toolhead board en lidar vervangen. Het grootste gepriemel was de toolhead kabels en die van de lidar terug achter het pcb en toolhead clips krijgen zonder dat ze geklemd gingen zitten bij het vastschroeven van het main toolhead pcb.
3D Wens Shop
Gefeliciteerd met de aankoop van de X1C is voor mij ook mijn primaire machine en heeft al ongeveer 4000 uur geprint. Daarnaast heb ik nog een P1S, waar ik ook ontzettend tevreden mee ben. Enig nadeel van laatst genoemde, vind ik, is het ontbreken van een live-cam en kleuren display, maar dat is het grote prijsverschil niet waard t.o.v. de X1C. Dus mocht er nog een derde machine bijkomen wordt het toch een P1S.
3D Scanner: 3DMakerPro Moose
Dat LCD gebrek kan je 'oplossen' met een BigTreeTech panda touch, de live cam zijn genoeg externe opties voor
3D Wens Shop
De BigTreeTech panda touch is inderdaad wel een interessante upgrade. Vanavond ff wat reviews erbij pakken.
Hou er wel rekening mee dat het externe hardware is, en "support" niet gegarandeerd is. Is sinds release al 1x "defect" geweest door een printer firmware upgrade maar werkt voorlopig wel weer.
De resultaten zijn indd helemaal top..
Ik print voornamelijk voor mijn modelspoorbaan maar dit ziet er echt perfect uit hoor.
En onderdelen vervangen zien we tegen die tijd wel weer,had al gezien dat ze een duidelijke wiki hebben en gelijk aangeven met QR codes.
En anders is hier ook de juiste hulp te vinden gelukkig.
verder nog wel een paar vraagjes
krijg vaak de melding dat het beter is om de deur open te laten staan om verstopping te voorkomen maar is dit echt nodig?
Ik print voornamelijk met PLA
Inmiddels al een paar rollen voor de helft leeg geprint en nu al een paar keer bij meerkleurige prints,
Dat hij tijdens het wisselen van filament soms niet direct de kleur inlaad maar een melding geeft.
En als ik die weg klik pakt hij hem daarna wel gewoon.
Prints in 1 kleur gaan perfect.
Dit zijn plastic rollen van 1233d en Fill3d
En waar kan ik zien hoeveel uur de X1 nu geprint heeft? haha
Bambu Lab x1 combo
Snapmaker J1
Snapmaker J1
In het menu - statistieken .
