Revopoint Miraco Pro Complete kit  [VERKOCHT]
Geplaatst: 27/04/25, 15:59
Werd nieuw aangekocht voor bijberoep, echter onverwacht bijberoep moeten stopzetten wegens verhuis naar sociale woning en zit anders boven inkomenslimiet. Werd nooit gebruikt voor opdrachten
Deze set is ONGEBRUIKT en nieuw. Bevat:
Revopoint Miraco Pro 3D scanner twv 1459€ kit (incl tripod, mini turntable, near mode calibration board, magic mat, pols strap, lader en scanner tas)
2 bussen AESUB scanning spray @ 39.99/st
Large Turntable (tot 200kg) @ 446€
Dual-Axis Turntable @ 115€
Portable Turntable @ 39€
High Precision Large Calibration Board Kid @ 49€
Een totale waarde van 2188€. Wordt enkel als COMPLETE SET verkocht
Specs via officiële website
Product: Revopoint MIRACO Pro https://global.revopoint3d.com/en-eur/p ... ner-miraco
Technology: Quad-camera Infrared Structured Light
Single-frame Accuracy: up to 0.05 mm
Fused Point Distance: up to 0.05 mm
Single Capture Area at Nearest Distance: 28 x 53 mm at 100 mm
Single Capture Area at Furthest Distance: 975 x 775 mm at 1000 mm
Two Capture Modes: Single-shot Mode, Continuous Capture Mode
Scanning Speed, up to: 15 fps
Minimum Scan Volume: 10 x 10 x 10 mm
Maxmium Scan Volume: 4 × 4 × 4 m
Working Distance: 100 - 1000 mm
Screen: 6” 2k AMOLED Touch Screen
Auxiliary Lighting: Infrared Fill Lights, White Flash LEDs
3D Light Source: Class 1 Infrared Light
Storage: 256 GB eMMC
Position Sensors: 9-axis IMU
Memory (RAM): 32 GB DDR4
RGB Camera Resolution, up to: 48 Megapixels
Scanner Weight: 750 g
Dimensions(L x W x H): 200 x 50 x 110 mm
Battery Capacity : Internal lithium Battery 5,000 mAh,
supporting up to 2-hour continuous scanning
CPU : 8-core CPU,2.4 GHz
Tracking Methods: Feature , Marker, Global Marker
Protection Rating: IP45
Connector Type: USB Type-C
Wi-Fi Type: Wi-Fi 6
Compatible Operating Systems: Windows 10/11 (64-bit), macOS 11.0 or better
Operating System : Native Android System
Special Object Scanning: Use scanning spray for transparent, dark, or highly reflective objects
Scanning Environment: Indoors and Outdoors
Output File Formats: PLY, OBJ, STL, ASC, 3MF, GLTF, FBX
3D Printing Compatible: Yes
Built in Chip Computing : Depth Map Computing, 3D Scanning, Point Cloud Processing and Editing
Mobile Requirements: N/A
Minimum PC Requirements:
macOS
CPU: M1 Pro or better;
RAM ≥ 8GB
Recommended PC Requirements
Windows
CPU: Intel i7 12th Gen or better;
RAM ≥ 16GB
Scanning Spray https://global.revopoint3d.com/en-eur/p ... ning-spray
Brand: AESUB
Compatible Devices: POP, POP 2, POP 3, POP 3 Plus, MINI, MINI 2, INSPIRE, MIRACO, MIRACO Pro, RANGE, RANGE 2, MIRACO Plus, MetroX
Behavior: Vanishing/Volatile
Container: Can
Volume: 400ml
Scannable Time: ≤ 1h
Sublimation Time: ≤ 4h
Approx. Layer Thickness: 8-15um
Working Temperature: 21 ℃ (69.8 ℉)
Hazardous Labeling: Flammable
Recommended For: Structured Light and Laser Scanning
To be Applied: Manually, via Spray Can
Large Turntable: https://global.revopoint3d.com/en-eur/p ... -turntable
Specificaties:
Product Name: Large Turntable
Parts Included: Large Turntable × 1, Remote Controller × 1,
Power Cable × 1, Adapter × 1
Power Output: 24V/3A
Compatible Devices: POP, POP 2, POP 3, RANGE, RANGE 2, INSPIRE, MIRACO, MIRACO Pro, POP 3 Plus, MIRACO Plus, MetroX
Dimensions: (D) 500 mm × (H) 100 mm
Speed: 35 - 90 Seconds per Rotation
Max Load: 200 kg (≈ 441 lbs)
Weight: 7 kg (≈ 15.4 lbs)
Control Method: Via Remote Controller / App Over Bluetooth
Rotation Control: Direction, Speed and Start/Pause
Noise: ≤ 55 (db)
Main Materials: ABS + PS
Dual Axis Turntable: https://global.revopoint3d.com/en-eur/p ... -turntable
Specifications
Product Name: Dual-axis Turntable
Parts Included: Multi-region Adapter × 1, Turntable Topper × 1,
Dual-axis Turnable × 1,: Power Cable × 1, Reusable Sticky Pad × 1
Model: A230-Ⅱ
Power Output: 12V/2A
Compatible Devices: POP, POP 2, POP 3, MINI, RANGE, INSPIRE,
MIRACO, MIRACO Pro, RANGE 2, MINI 2, POP 3 Plus, MIRACO Plus, MetroX
Dimensions: (D) 200 mm × (H) 82 mm
Weight: About 771 g (≈ 1.7 lbs)
Turntable Speed: 18 - 90 Seconds per Rotation
Max Load: 5 kg (≈ 11 lbs)
Color: Black
Rotation Control: Via Buttons / APP (Revo scan/Revo assistant)
Controls: Direction, Tilt, Speed, and Start / Pause
Portable Turntable: https://global.revopoint3d.com/en-eur/p ... -turntable
Specifications
Product Name: Portable Turntable
Parts Included: Mini Turntable × 1, Reusable Sticky Pad × 1, Turntable Power Cable (USB Type-A to Type-C) × 1, Extended Table × 1
Material: ABS
Color: Black
Power Output: 5V/1A
Dimensions: (D) 125 mm × (L) 42 mm
Power Supply: USB Power Supply
Function: Motorized 360° Rotation
Weight: 315 g (≈ 0.7 lbs)
Max Load: 2.5 kg (≈ 5.5 lbs)
High Precision Large Calibration board kit https://global.revopoint3d.com/en-eur/p ... ard-miraco
Specifications
Name: Large Calibration-board Kit
Compatible Devices: MIRACO, MIRACO Pro, MIRACO Plus
Parts Included: Calibration Board × 4, Large Calibration-board Sheet × 1
1) Calibration Board
Size: 410 × 260 × 8 mm
Material: PVC
Weight: 1500 g
2) Large Calibration-board Sheet
Size: 1000 x 800 mm
Material: PE
Weg ter financiëring voor toekomstige PrusaXL :p
Re: Revopoint Miraco Pro Complete kit
Geplaatst: 28/04/25, 19:29
door PaulM
Jammer dat je niet los verkoopt. Ik had wel interesse in je large turntable :)
(nog steeds tevreden van die Range die ik destijds van je kocht)
Mocht je later overwegen om toch los te verkopen... laat maar weten he.
Geplaatst: 28/04/25, 22:39
Om de set op te splitsen is het nu nog wat te vroeg. Wel grappig om te zien, de hele set staat ook op 2e hands en dan krijg je van die belachelijke biedingen van 450 en 500€. 2200€ aan spullen weg doen voor 500? Ik dacht het niet
Geplaatst: 30/05/25, 14:04
Veel plezier en succes met de kit @Zappa! Fijn je te leren kennen en dank voor het bezoekje :)
Geplaatst: 30/05/25, 22:41
door Zappa
Dank je @Ch3vr0n.
Alles werkt naar behoren. Nu eerst even bijkomen van de trip en dan morgen écht aan de slag met de scanner.
Heel leuk om onze forumbeheerder eens in levende lijve te zien. Veel dank voor de gastvrije ontvangst. 👍
