The forum Administrator has chosen to advise you that this topic is 2 months en 3 weeks old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
Op de camping? :shock: Noem je dat vakantie houden?
Nu ja, het ziet er toch goed uit. :mrgreen:
